whenever i try to compile my DVD in maestro, it gives me this error:
Starting DVD Build FMA 1-9...
Compiler Initializing...
Creating DVD Directories in C:\Documents and Settings\Owner\My Documents\My Received Files\Full Metal Alchemist\New Folder\Project_1\
Cleaning directory.
Cleaning directory.
Compiling VMG Information...
Created 26 PGCs in VTSM1
Created 5 PGCs in VTSM2
Created 5 PGCs in VTSM3
Created 5 PGCs in VTSM4
Created 5 PGCs in VTSM5
Created 5 PGCs in VTSM6
Created 5 PGCs in VTSM7
Created 5 PGCs in VTSM8
Created 5 PGCs in VTSM9
Created 5 PGCs in VTSM10
Created 16 PGCs in VMG.
20 Menu(s) will be created...
Compiling Menu PGCs...
Compiling Menu#1 (Main Menu)...
Compiling Menu#2 (Episodes)...
Compiling Menu#3 (1)...
Compiling Menu#4 (2)...
Compiling Menu#5 (3)...
Compiling Menu#6 (4)...
Compiling Menu#7 (5)...
Compiler Error: Invalid Frame Rate
Build canceled
it doesn't only happen on that menu, it happens on any random menu. the highest it has ever gotten is to menu 13 i believe.
i can't figure out what the problem is, and i tried searching but couldn't find anything.
i will provide any information needed, just let me know.
please help.
thanks.
does your menus have video motion background? what is the video source then?
Easy to fix. This is to do with using CPUs that have hyperthreading or are multi-core.
To fix this, bring up windows task manager (CTRL ALT DEL). Under "Processes" find "DVDMaestro.exe". Right-click it and "Set Affinity". UNCHECK one of the CPUs.
You need to do this every time you start the program, but you will never get the "invalid frame rate" error again. -
thank you skeg64. what you told me to do helped stop the problem
i would have never thought it was a program problem, since i have been having errors gallore trying to get these file ready for DVD compilation and have run into problem after problem.
thanks again!
PS: Baldrick: my menu's don't have video motion background. i haven't delved that deep into menu creation yet... maybe later. right now i just want to complete the DVD iam working on. the problem is fixed now, but thanks for replying. -
Originally Posted by skeg64
I have recently upgraded to a dual core CPU and this error drove me CRAZY this weekend, it only happens on static menus, randomly, I have just built a DVD with 8 static menus and couldn't compile it after hours trying
I'll try this patch at home tonight !
THANKS VERY VERY MUCH !!
Zetti
ffmpegX mpeg2enc compiling problem
By dubis in forum MacReplies: 5Last Post: 12th Sep 2008, 16:54 -
Bitrate question compiling a DVD
By dvdnewb2 in forum Video ConversionReplies: 6Last Post: 18th Aug 2008, 08:31 -
Compiling a DVD
By LiCal in forum Newbie / General discussionsReplies: 2Last Post: 25th Apr 2008, 13:31 -
DVD Lab Pro Error b4 compiling
By _yoyo in forum Authoring (DVD)Replies: 1Last Post: 20th Apr 2008, 18:39 -
a problem with result DVD after compiling with DVD-Lab
By soroush in forum Authoring (DVD)Replies: 4Last Post: 11th Dec 2007, 14:58
