    Jul 2001
    I have a bunch of AVI files with Japaneese on the left audio channel and English on the right. I want to keep just the English, which is done easily with VirtualDub.
    But, since there is a whole bunch of files I would like to do this in a batch process (i.e. probably using command line tools). I can create an AviSynth script with does this for me, but how would I (batch-wise) put the AviSynth output in a new .avi file?
    I also tried AVIMaster, which I could not get to remove only left or right. I tried to combine AviSynth and AVIMaster, since AVIMaster can output a new file, but AVIMaster could not read the AviSynth script.
    Ideas???
    What other command line AVI tools are there?
    Dec 2004
    Australia
    Problem with AVISynth is that unless you use the DSynth mod, you have to re-encode the video to.
    Should be possible using mencoder with -ovc copy, say -oac mp3lame. Can't remember the command to control the audio channels off the top of my head though though.
    Anyway, once you have it setup you can just use a for command to process all the avi's.
    ffmpeg should also be able to do it.
    Jul 2001
    mencoder seems to do the job. Thanks!
