OK, I used SmartRipper 2.4 to rip a DVD and it created a list of VOB files and one ifo file and one txt file as said on this procedure.
I then use the DVD2AVI 184 and follow the procedure as it said but did not see any audio file? I only create a d2v file? Please help?
one more thing please do not use DVD2AVI 1.84 or 1.85 if your are going to do a Forcedfilm framserve....these versions put the Fps as 24 instead of 23.967 and you will get out of sync video..if your going to do forcedfilm use version 1.76 or 1.74...but if your are doing PAL or just NTSC those versions are fine
PS3 won't play audio for this file (specs included)
By bound4h in forum AudioReplies: 1Last Post: 21st Jul 2010, 19:16 -
Are there any (free) tools to mux (insert) audio w/out create new file ?
By vhelp in forum AudioReplies: 2Last Post: 11th Dec 2008, 05:15 -
VOB2MPG won't create the mpg
By Heibi in forum Newbie / General discussionsReplies: 6Last Post: 6th Sep 2008, 17:34 -
How would I create points or chapters throughout my mp3 audio file???
By Hittz in forum AudioReplies: 5Last Post: 17th Feb 2008, 22:18 -
DVD won't read...won't create avi thumbnails
By ru5ty in forum DVD & Blu-ray WritersReplies: 6Last Post: 27th Jul 2007, 20:04
