Keeps the smoothing to the darker areas of the pictures. Gives greater compression without sacrificing visible image quality. Reducing detail on shadows saves bitrate on areas to where your eyes aren't paying much attention. Also, it is good on noisy, blocky dark areas that show up from AVI and some MPEG sources.
Worth a look. I use it quite a bit, as it reduces black and dark colored noise pretty well.
Read the Author's "Quick Cookbook" on Suggestions for Getting Started
http://www.geocities.com/gc_timsara/vdub.html
Results 1 to 1 of 1
WebEx WMV file, can't open in VirtualDub, says "missing codec"
By violetta in forum Newbie / General discussionsReplies: 13Last Post: 22nd Jul 2016, 21:39 -
how to "plug-in" virtualdub?
By ledishis in forum Newbie / General discussionsReplies: 1Last Post: 4th Apr 2012, 13:38 -
VirtualDub Error 'Says "Couldnt locate decompressor for format xvid"
By shashgo in forum Newbie / General discussionsReplies: 3Last Post: 21st Jul 2010, 23:05 -
how we can implement "VirtualDub" or "FFmpeg" with my C# windows applicati
By dhemittal in forum ProgrammingReplies: 0Last Post: 8th Jun 2010, 07:17 -
"smoother" plugin for avisynth script
By Lastman369 in forum Video ConversionReplies: 5Last Post: 21st May 2010, 13:17
