im trying to convert pal to ntsc, so-far ive demux all vob merged them together (file.mpg) encoded to file.m2v
I still have to use dgPulldown for the frame rate, but i'm concerned about the audio, how do i get the audio out of the 4 vob files? then how do i get it to ac3 format? so i can use TMPGEnc DVD author to finalize.
thx
Hi-
...how do i get the audio out of the 4 vob files?
If you have the IFOs, you can use PGCDemux. If you don't, you can load the vobs into DGIndex and get it. There are other ways as well.
...then how do i get it to ac3 format?
You sure it's not already AC3? Most DVDs have AC3 already. If it's WAV, then you encode the WAV to AC3 using freeware such as BeSweet, or a commercial encoder such as SoftEncode. There are also other encoders available. -
Question:
How do you convert AND change the audio? I love the job that DGpulldown does but PAL Speed-up drives me mad. Is there any way to convert pal to the proper frame rate AND change the speed to "normal" as well?
Pls help! Best way to convert NTSC VHS (captured using PAL VCR) to NTSC DVD
By rairjordan in forum Capturing and VCRReplies: 33Last Post: 28th Nov 2013, 12:33 -
when Pal dvd has correct Ntsc audio (Pal>Ntsc conver)
By spiritgumm in forum Video ConversionReplies: 15Last Post: 13th Oct 2011, 13:57 -
PAL to NTSC, NTSC to PAL framerate conversion?
By Baldrick in forum Video ConversionReplies: 44Last Post: 6th Dec 2009, 00:31 -
Creating NTSC Blu ray DVD From PAL TS Files. need help with NTSC format
By Rick0725 in forum Authoring (Blu-ray)Replies: 0Last Post: 9th Apr 2009, 22:43 -
NTSC to PAL, PAL to NTSC framerate conversion?
By Baldrick in forum Video ConversionReplies: 23Last Post: 23rd Apr 2008, 12:19
