I have a .dat file that I would like to burn to dvd. I've searched the forums but can't seem to find a straight answer on which program to use to burn the .dat file to dvd and how. Thanks.
Closed Thread
the dat is probably a vcd. www.videohelp.com/vcddvdr , skip isobuster and try add the dat directly to tmpgenc dvd author or use vcdgear to convert to a mpg.
I have already extracted the mpegav file using Isobuster. Now I have the .dat file. What do I do with that. I'm not trying to be difficult, just new at this.
continue in your first topic. just reply to add more information.
https://www.videohelp.com/forum/viewtopic.php?t=277093&highlight=
how to seperate audio from DAT file
By pcb in forum AudioReplies: 5Last Post: 4th Jul 2011, 15:51 -
What is the DAT file?
By coody in forum Video ConversionReplies: 3Last Post: 22nd Mar 2010, 21:29 -
.Dat File?
By niteghost in forum Video ConversionReplies: 3Last Post: 24th May 2009, 22:38 -
Video dat file played only like audio file
By newbievideohelp in forum Software PlayingReplies: 9Last Post: 14th Oct 2008, 20:31 -
How to extract a .wmv file from inside a .dat file
By Toastie in forum Video ConversionReplies: 2Last Post: 17th Jun 2007, 23:06
