Hi!
Can anyone show me how to fix AC_3 encoder problem in TMPGEnc.This what it says: can not find the dolby digital
installing the TMPGEnc sound plug-in AC_3 allows to encode
and decode dolby digital audio
THANKS so much inadvance
Trust me, I'm not looking to start a flame war here - but have you purchased the AC3 encoder for TMPGenc?
There have been numerous posts in the past from those who've tried using the 'hacked' version, only to discover it doesn't work.
If you have purchased it, follow the instructions in the ReadMe.txt file for the installation instructions. It should help you get that going, ok?
Post back and let us know!
Cheers!
TTWC"I've got a present for ya!" - TTWC
which is better Mainconcept MPEG Encoder or H.254 Encoder
By d_unbeliever in forum Newbie / General discussionsReplies: 7Last Post: 4th Aug 2012, 19:14 -
How it possible Video: X264 encoder with Matroska encoder extension?
By flash_os in forum Newbie / General discussionsReplies: 1Last Post: 11th Feb 2012, 10:13 -
Your Best Video Encoder/Re-encoder???
By iqbal88 in forum DVD RippingReplies: 2Last Post: 15th Aug 2011, 09:09 -
Hc Encoder
By pcb in forum Video ConversionReplies: 12Last Post: 28th May 2010, 14:15 -
Error with Nero AAC encoder in XVID4PSP - "Could not open AAC encoder&
By TheViking in forum Video ConversionReplies: 2Last Post: 5th Nov 2009, 02:41
