I didnt know where else to ask for this help but I thought I would try here.
I have been asked to make a slideshow on a dvd of 3 photos, thats easy enough but they have also asked for the photos to be displayed for a certain amount of time.
One photo for 6 seconds and then the other two for 7 seconds and then the slideshow should finish.
please can someone tell me if this is possible and if so, how.
any help would be greatly appreciated.
Many thanks
have you tried any photo dvd tool like memoriesontv ?
and should it be a dvd-video? -
proshow and XAT also ..
that dvd is so small it might have some compatability issues ..
have at least 1 GB on there of even junk data .."Each problem that I solved became a rule which served afterwards to solve other problems." - Rene Descartes (1596-1650) -
Is it going to loop or is it really going to play for such a short time?
It might be best just to use a video program like Pinnacle Studio and create a video of those still shots repeating over and over. There probably is no need for a Slide Show program. -
Try Photo2DVD Studio. It's a nice piece of application for creating dvd photo slideshow. If you want to create DVD slideshow with narration record, PPT2DVD is another solution.
Many thanks for all of the replies, you are all a credit to such a good forum.
I used memoriesontv and it worked fine, it wasnt to loop and yes it was a very small amount of data for a dvd but I just do what im told.
thanks again you lot.
[beta] Bolide Slideshow Creator - Free AVI/MKV/WMV slideshow maker
By bolide in forum EditingReplies: 5Last Post: 30th May 2012, 04:18 -
DVD Photo Slideshow
By jet757f in forum Newbie / General discussionsReplies: 9Last Post: 13th Dec 2010, 13:54 -
DVD Slideshow GUI help
By snafubaby in forum Newbie / General discussionsReplies: 11Last Post: 9th Sep 2010, 16:15 -
rip dvd with slideshow
By wingfan in forum Newbie / General discussionsReplies: 2Last Post: 25th Nov 2007, 18:06 -
DVD Slideshow GUI
By Tripodd in forum Authoring (DVD)Replies: 0Last Post: 27th Jul 2007, 15:19
