Can we add subtitles to an AVI file, which can be switched while watching the movie. I mean like how it is in a DVD.
Pls tell me if such a technique is available, and if there are any seperate softwares used to view AVI files encoded in that manner.
Yeah but your gonna have to wrap it in an .ogm or .mkv container with virtualdubMod.
This guide will help you somewhat https://www.videohelp.com/forum/viewtopic.php?t=241422, but there is all the neccessary tools and codecs you will need.
Just load .avi, go to streams list and add whatever audio or sub streams you have. Make sure video is set to direct stream, then save as .ogm, or .mkv .Quality is my policy. -
avi supports multiple subtitle streams fine. You can switch between them or switch them off.
You can make switchable subtiles by converting subtiles to xsub and mux the xsub with your avi (divx/xivd) files. The output .divx file can even be played on hardware player.
Tools needed: srt2bmp, bmptoxub, fuse.
These can be searched in this forum.
How to delete/switch default language in a MKV file
By gquiring in forum Newbie / General discussionsReplies: 5Last Post: 27th Feb 2015, 19:35 -
How Can I Remove the Subtitles from a .VOB File and a .AVI File?
By channelz28 in forum Newbie / General discussionsReplies: 3Last Post: 21st Nov 2011, 19:45 -
adding subtitles to avi file
By dragonhead08 in forum ffmpegX general discussionReplies: 1Last Post: 2nd Jan 2009, 08:18 -
display problem switch from pc to tv, can't switch back
By samiam5156 in forum ComputerReplies: 1Last Post: 11th Oct 2007, 09:23 -
Need subtitles for an AVI file
By kellindal in forum SubtitleReplies: 5Last Post: 3rd Oct 2007, 16:54
