I've recorded some TV shows using my video capture card in MPEG format. I'm pretty sure they are near DVD quality (each hour long show takes up ~1.6 GB). I edited all the commercials out using Ulead DVD Movie Factory 3 SE, but understandably the files are still huge. So, what I want to do is shrink the files down to a smaller size, and ultimately author them onto a DVD. What is the best program to use to shrink the file size down? I know I need to reduce resolution and/or fps, etc., but what's the best/easiest way of doing this? I have access to some powerful programs, such as Adobe Premier, as well as the multitude of free programs out there. I'm not looking to spend any money on buying any other software though.
Any help would be greatly appreciated.
Bill
Well, since the deed is done (you've captured at a too high bitrate), just go ahead and author it as an "oversized" DVD to HDD(let's say using TMPGEnc DVD Author). Then shrink to fit a DVD5 using DVDShrink.
I'd go as far as suggesting you do your commercial cutting in TDA too, to avoid the Ulead step.
/Mats
converting HD mov to smaller size
By bolter in forum ffmpegX general discussionReplies: 1Last Post: 13th Dec 2011, 13:47 -
Converting videos -> smaller file size
By karib in forum Video ConversionReplies: 4Last Post: 10th Dec 2010, 15:31 -
Best way to convert DV file to something that have smaller file size
By Cazz in forum Video ConversionReplies: 27Last Post: 8th May 2010, 07:14 -
Smaller file size after Video Capture (help)
By convoy71 in forum Capturing and VCRReplies: 4Last Post: 4th Apr 2009, 18:05 -
Converting MPEG into a smaller file size?
By ione in forum Video ConversionReplies: 3Last Post: 9th Sep 2008, 23:36
