I use Dgmpegdec as my soundseparating software. I use Smartripper to extratc the VOBs I want and then run Dgmpegdec.
On som DVDs I get an error message:
Warning. Opening GOP is not closed.
The first few frames might not be decoded correctly.
When I recieve this message the program can't extract the sound. Is there a way that I can bypass this or a setting in the VOB-ripping process that eliminates this? I have tried using DVDshrink to extract the VOBs and the same problem occur so it doesnt seem to be the program but the DVD or some setting I missed tweaking.
/K
Hi-
Personally, I have no trouble getting the audio even when the first GOP isn't closed. However, you might try the latest version. It's listed on the front page of this site. -
Smartripper has the ability to demux files whilst ripping:
Basically you tick the streams you want to keep, then for those you want to demux, select them and then click on "demux to extra file".If in doubt, Google it.
VOBs burned to DVD have sound missing on TV (but play OK on PC)
By martinlest in forum Authoring (DVD)Replies: 3Last Post: 29th Mar 2012, 06:17 -
Separating out a voice in the crowd
By and in forum EditingReplies: 1Last Post: 8th Dec 2011, 08:20 -
separating audio and re-authoring
By joecass in forum Newbie / General discussionsReplies: 1Last Post: 23rd Dec 2010, 10:37 -
MPEG-2 VOBs trouble in VirtualDub
By shmizan in forum Video ConversionReplies: 4Last Post: 16th Apr 2010, 09:35 -
Separating audio
By Jeikobu in forum MacReplies: 12Last Post: 9th Jun 2008, 04:39
