I've a 1.36 GB AVI file with the following specifications:
Average video bitrate -> 1890 Kbps
Audio bitrate -> 192Kbps mp3
Resolution -> 720 X 384
Aspect Ratio -> 4:3
Length -> 1hr 33min 41sec
The above video had been encoded from an MPEG2 video using AutoGK in 100% Target Quality mode, and DivX v6.0 codec.
Note: I don't have this original MPEG2 video with me now. All I've is the 1.36 GB AVI file.
Now, keeping the same resolution, I want to reduce the 1.36GB AVI file to a 700MB file. If I use AutoGK once again, the resolution will be changed(as AutoGK determines a particular calculated resolution during the process of encoding by running a compressibility test for files having a Custom Size)
So, the only method I thought inorder to reduce the filesize, without changing the resolution is:
1.) To open the 1.36 GB AVI file in VirtualDubMod.
2.) Configure the DivX codec settings to reduce bitrate(using the in-built bitrate calculator).
Using bitrate calculator, I found that the bitrate comes out to be 845Kbps(aprrox.).
Now, I'm aware of the fact that reduced bitrate definitely reduces the quality to a certain extent. But, I guess there are certain techniques to improve(or retain) the original quality like:
1.) Multipass, 1st pass encoding
2.) Multipass, Nth pass encoding
I don't know how to use the above two features of the DivX Codec while working with VirtualDubMod. Pls explain the above two encoding techniques so that I can get the best quality despite the reduced bitrate.
To be more specific, pls explain the procedure of Multipass encoding of DivX while working with VirtualDubMod.
Results 1 to 11 of 11
You would do the first pass. This creates a stats file. Then run as many Nth passes as you want, each time the stats file is further updated.
Realistically though it will only help to a point and when the bitrate reaches a point you will get better quality by resizing down. ie. the smaller encode when resized back up looks better than the non resized version. -
Originally Posted by celtic_druid
Pls explain the procedural steps to encode a video using Multipass, 1st pass and Multipass Nth pass. How do I actually run an Nth pass encoding. -
Where ever you tell it to I would imagine.
The stats file will automatically be updated. -
If you need to reduce it in order to burn onto a CD, you could keep everything the same and just split it and burn to 2 CDs...no quality loss that way.
Why not burn as data to a dvd-r?
No DVD can withstand the power of DVDShrink along with AnyDVD! -
guys, pls give me the answer to my question. the topic is getting deviated.
Originally Posted by plomon
Since splitting the file into 2 smaller files would suffer no quality loss whatsoever, I fail to see how I am deviating from the topic (if you were referring to me).
PS: I'm not a guy -
Originally Posted by somebodeez
Conversion of larger AVI to smaller with maximum quality.
Do you think it is same as this:
Splitting of larger AVI into smaller AVI.
I don't think so.
If you didn't get my point, let me put forward the issue in a more simpler way:
I've a 1.36 GB AVI file. I want to compress it into a 700MB file using DivX v6.0 codec in VirtualDubMod with the help of Multipass Nth pass encoding method.
I don't know, how to encode an AVI file using Multipass Nth pass encoding technique.
Now, I guess you must atleast be knowing why I wanna use Multipass Nth pass. The reason is simple:
coz, obviously, it gives better quality(even for small filesize i.e., consequently smaller bitrate videos) than single pass encoding.
So, all I wanna know about is the procedural steps of how to proceed with the encoding of an AVI file using Multipass Nth pass encoding technique of DivX codec in VirtualDubMod. -
My suggestion would've not only given you max quality but saved you reencoding time as well.
Besides, you've already started a topic asking about how to use multiple passes :
https://www.videohelp.com/forum/viewtopic.php?t=277527&highlight=&sid=f440719d225cc9f4f...36eab751f51ea5
I humbly bow out of this topic. -
It doesn't take much to say thanks for free help - beggars can't really be choosers
As for your issue, you can in fact use AutoGK - Go into the advanced options, and set the width to Fixed Width and put in 720. Then choose 1 CD (700MB) in the Target size area and it'll do it all for you.If in doubt, Google it.
Best quality flv to avi conversion
By Johnbil in forum Video ConversionReplies: 4Last Post: 22nd Mar 2012, 19:05 -
Convert DVd to xvid avi best quality for max size 900mb
By selwyns2828 in forum DVD RippingReplies: 6Last Post: 10th Feb 2011, 17:02 -
Lagarith codec producing larger filesize with smaller resolution?
By BozQ in forum Newbie / General discussionsReplies: 22Last Post: 15th Sep 2009, 10:11 -
2 Small-ish AVI -> 1 Larger AVI = HUGE File. Why?
By cxp36 in forum Newbie / General discussionsReplies: 2Last Post: 6th Mar 2008, 17:31 -
Rendering should yeild smaller, not larger files right?
By InFlames814 in forum EditingReplies: 9Last Post: 4th Dec 2007, 22:21
