  1. Member Sakuya's Avatar
    Dec 2002
    This is a strange problem. I cannot back up my DVD because DVD Shrink cannot find the VIDEO_TS.VOB. The DVD plays fine though. I used DVD Decrypter on the DVD but I still cannot open the VOBs using DVD Shrink. I tried burning it with TMPGEnc DVD Authoring's burn tool but it won't burn because "it's not made to play on a DVD player". What should I do now?
  2. Member ebenton's Avatar
    Jul 2003
    The WINDY state (Florida)
  3. This is a strange problem. I cannot back up my DVD because DVD Shrink cannot find the VIDEO_TS.VOB. The DVD plays fine though
    What do you mean? Can YOU see the .vob files on the disk by using explorer? Exactly what files are on the DVD?
  4. Member otpw1's Avatar
    Jan 2005
    midwest USA
    Was the source disc recorded on a dvd recorder?
    A good divorce beats a bad marriage.
    Now I have two anniversaries I celebrate!
  5. Member Sakuya's Avatar
    Dec 2002
    Yes I can see the VOB files. There is a VIDEO_TS.BUP and VIDEO_TS.IFO and then the usual VOBs. I'm not sure if it was recorded on a DVD recorder. It looks like a bootleg DVD.
    In the end, I used Nero to burn the project anyway and it works. That's so weird. Thanks anyways.
