I got some movies on SVCD and want to burn them on DVD. I was wondering what would be the best way to do this. Should I rip the SVCD and then encode them as DVD.
Also found some guide on how to do this with DVDLab, but not sure if this was a good way to do this. Since SVCD is 480x480 how will that work if I use the guides here? Would it convert it to DVD specs?
How is that aspect ratio going to be affected?
Quality wise it's best not to re-encode, the problem is that not all players can handle SVCD resolution on a DVD as it is not DVD spec. The DVD-Lab method is good, you can try it and see if it plays for you but don't count on it working on other machines.
Re-encode if necessary to get full DVD compliance."Art is making something out of nothing and selling it." - Frank Zappa
Help with svcd 2 dvd
By tastybaker in forum SVCD2DVD & VOB2MPGReplies: 5Last Post: 11th Aug 2010, 10:30 -
Svcd 2 dvd
By GeordieDave in forum SVCD2DVD & VOB2MPGReplies: 1Last Post: 8th Feb 2010, 11:05 -
VCD to DVD (not SVCD)
By noyou in forum SVCD2DVD & VOB2MPGReplies: 20Last Post: 19th May 2009, 17:56 -
Can a SVCD video file be burned on to a DVD and played in a DVD player?
By dvdnewbie64 in forum Newbie / General discussionsReplies: 9Last Post: 17th Apr 2008, 21:44 -
How to burn a SVCD onto a DVD?
By php111 in forum Authoring (VCD/SVCD)Replies: 9Last Post: 16th Oct 2007, 03:32
