  1. Hello,
    I recently have tried to convert a couple of .Avi files on my computer to DVD compatible files so i can use my DVD Shrink application to shrink the file sized down to fit more than one or two files onto a DVD-R cd.. I've gone through all the help files on AVI2DVD and i am getting an error message when i try to run the job: Job NOT Done. There are warnings ... Find at the log file the 0 byte generated file to focus where exactly the problem appears. I am using the following options in AVI2DVD: Output, tried checking and unchecking Make ISO, Pal to NTSC Encoders, HCEnc
    Please HELP!!!
    carbfrze
    "Beeflog, beeflog what a treat! A hefty hunk of processed Meat! Dipped in mustard oh what JOY! I'm a jolly Beeflog Boy!!!"
  2. proctor
    Guest
    I'm having these same problems...
    [21:51:39] AVI2DVD Started !
    [21:51:40] Type mode : Avi Input
    [21:51:40] Output : Dvd
    [21:51:40] Encoder Selected : QuEnc
    [21:51:40] Start demuxing the AudioStream No.1 ...
    [21:51:55] Demuxing of the selected audio finished
    successfully ! [D:\Season 7
    \Avi2dvd_temp\Extracted_Audio.mp3 10473424 Bytes]
    [21:51:55] Audio extracted renamed successfully !
    [D:\Season 7\Avi2dvd_temp\Fixed_Audio01.mp3
    10473424 Bytes]
    [21:51:55] Starts Mp3->Ac3 convertion ...
    [21:51:56] Ac3 generated successfully ! [D:\Season 7
    \Avi2dvd_temp\AudioStream 1 MP3 2CH.ac3 0 Bytes]
    [21:51:56] Job NOT Done. There are warnings ... Find at
    the problem appears
    don't know what to do or who else to turn to since I didn't find a support email/forum for the software.
    any ideas?
    I would try some other all-in-one tool like divxtodvd,diko,thefilmmachine. avi2dvd is still a beta.
  4. proctor
    Guest
    Thanks mate, also found the forum there and it seems that lots of people are having this issue. I'm giving dvdSanta a go now
