hi all,
been reading like crazy. started out all i wanted to do was make some backups of my dvd's. don't want to really lend them to friends. had some cd's that look like a herd of cats used it for a scratching post.
anyway, capture cards are for direct conversion to mpeg from analog video. the dv-bridge is for analog to dv then you can encode it to whatever you want but the capture quality is of highest possible quality depending on what you started with.
I still puzzled about a few things. do the capture cards allow you to do encoding in real time? ie. sony digicam into firewire to dv. you can then import that file into a application and convert in real time to mpeg?
i think i got the video editing and authoring figured out. which is the better authoring software for making menus and chapters and stuff?
thanks
fiddler
Unless you get a HARDWARE MPEG2 ENCODER like the Dazzle2, ADS Instant DVD, WinTV PVR, or some more expensive high-end devices, you will have to use SOFTWARE to convert to MPEG2. MPEG2 must be your final format for use on SVCD/DVD. Software encoding can take a long time (4:1 up to 10+:1 ratio).
On the other hand, DV and AVI are easier to edit.
I personally use two methods: (1) Analog-to-DV (using a Sony DA2 box...similar to the Hollywood DV Bridge but better) for "projects" where I need to do significant editing. (2) Hardware MPEG2 captures (using the ADS Instant DVD) for most "archival" stuff where I can pretty much use a straight capture with little editing.
Many people use inexpensive "TV" cards to capture raw AVI files, but the captured files are too LARGE to fool with in my experience.
Dood
Ivy Bridge to be up to 199% faster than Sandy Bridge
By deadrats in forum ComputerReplies: 33Last Post: 7th Dec 2011, 13:06 -
new Intel Sandy Bridge cpus
By kenmo in forum ComputerReplies: 19Last Post: 23rd Jan 2011, 12:48 -
New Intel Sandy Bridge cpu
By snafubaby in forum Newbie / General discussionsReplies: 2Last Post: 10th Jan 2011, 08:19 -
What is the difference between onboard & stand alone video cards ?
By Illusionist in forum ComputerReplies: 18Last Post: 22nd Dec 2009, 20:05 -
Adobe Bridge m2t files
By vegasarian in forum Newbie / General discussionsReplies: 0Last Post: 5th May 2008, 10:39
