Hi CB
I think I mentioned this to you many moons ago about the problem my DVD player has with the menus S2D creates.
Seeing as we are getting close to V2 FINAL, and I have been a paying user for a good while, I thought I would try and see if you could fix it.
If I have a menu, the menu screen comes up, then after about 5 seconds, it just automatically plays the first title. Then when the title finishes, it goes back to the menu, and 5 seconds later the first title plays again. I can move the cursor around during this time, but always title 1 plays.
Also, if I add music to the menu it just repeats the first 5 seconds or so over and over, like it is starting the menu from scratch every 5 seconds.
I have a MICO DVD Recorder, and it is based on a Philips chipset if this helps.
Cheers
Simon
I think i can see how this may be happening in your player. Let me try a few things at this end. Can you PM me your email address for when i have something for you to test?
s2d won't work after running Register Mechanic 9.0
By delgee65 in forum SVCD2DVD & VOB2MPGReplies: 1Last Post: 19th May 2011, 15:41 -
S2D have its own settings when using imgburn ?
By IPBR21054 in forum SVCD2DVD & VOB2MPGReplies: 0Last Post: 20th Aug 2009, 17:36 -
Can S2D do this?
By drbenjamin in forum SVCD2DVD & VOB2MPGReplies: 1Last Post: 28th Nov 2007, 18:25 -
How to save converted *s2d.mpg in another folder???
By junkfood in forum SVCD2DVD & VOB2MPGReplies: 1Last Post: 15th Sep 2007, 10:01 -
Nero Burner in new version of s2d version5
By couzican in forum SVCD2DVD & VOB2MPGReplies: 1Last Post: 3rd Jul 2007, 18:50
