Hello everyone, I converted a .avi into 4 different VOB files using DivXtoDVD, I Then burnt it onto a DVD using InterVideo WinDVD. THe .AVI version is really good quality, even when I transfered all the VOB files and I was watching the video play while it said, Making Movie.... the quality was excellent, and it was Wide Screen. But now when I watch it in the DVD player the video is good quality but there are huge black bars and you only have alittle strip where u can see the video playing, its like a full screen but worse because there is even less visual then usual, also the picture is slighly stretched out.ANyideas on how to fix this? I Burnt it NTFS 2 Hour DVD, I set it to 1 hour, but it wouldn't fit on 1 DVD. Thanks.
-Cory
i convert my avi's using TMPG enc Express, then i author them to DVD format using TMPG enc author, i get good results, but there is a few steps to take before you have your finished DVD, however if you want to keep the process simple you could always use a program like Cucusoft AVI to VCD,DVD,MPEG converter.
Hercules Man
Converting .VOB to .AVI
By reysaj in forum Newbie / General discussionsReplies: 11Last Post: 1st Dec 2010, 10:24 -
converting vob to avi or h 264 changes video proportions
By bob apple in forum MacReplies: 2Last Post: 19th Oct 2010, 23:39 -
Help with converting avi to vob
By music_freak in forum Video ConversionReplies: 1Last Post: 16th May 2009, 16:04 -
a good tool for converting avi or divx to the dvd vob format?
By extent in forum Newbie / General discussionsReplies: 7Last Post: 13th Jan 2009, 14:37 -
My utube video quality IS LOST when Shrunk - HELP!!
By Entry in forum Video Streaming DownloadingReplies: 1Last Post: 4th Nov 2008, 22:55
