After using tocsplit (selection 4) to create seperate tracks a cue file a gbf file and some bin files, What do I do to create a VCD using Nero? What are these files and what do they do?
Not familar with TOCsplit, but the bin file is animage file, and teh cue file/sheet is is the 'instructions' to burn it. Basically you load the cue sheet in your burner, and it uses the bin file as source.
I don't recommend burning bin/cue files w/ Nero (it can do it thou). Choose file | burn image. Then choose *.* (nero doesn't do cue files by default) then choose the cue file you want to burn.
I'd recommend burning bin/cue files w/ CDRDAO, a freeware program. But it's command line/dos based. So you'll want a GUI for it, either VCDEasy, TSCV, or Xduplicator. You can d/load
VCDeasy from http://www.doom9.org
TSCV from http://www.ttool.org
Xduplicator (do a google search) -
thanks for your help and the information. I'll try some of the recommended software. I appreciate the links.
cue and bin files
By natty in forum Newbie / General discussionsReplies: 2Last Post: 21st Jun 2011, 16:25 -
How to burn a .iso/bin,cue with nero
By Chupes in forum User guidesReplies: 5Last Post: 9th Sep 2009, 21:33 -
question how to burn bin/cue file to DVD disk
By jimdagys in forum Newbie / General discussionsReplies: 9Last Post: 17th May 2008, 12:58 -
What files/settings do I need for bin/cue
By Choppa in forum Authoring (VCD/SVCD)Replies: 9Last Post: 23rd Jun 2007, 22:29 -
How to merge 2 cue/bin to one DVD
By motleycool in forum Newbie / General discussionsReplies: 5Last Post: 7th Jun 2007, 22:26
