Hello Guys!
I've a little problem with the subtitles after using the program DIKO. When I convert an Avi movie into DVD format, burn it on a DVD and play the movie, the subtitles are too low in the TV screen and I can't see good the subtitle line most below...
There is a tab called 'subtitles' in the configuration of DIKO, like you see in the pic below...
The problem is that I don't can change numbers in this field, because the field is gray and I can't reach anything....
Does anybody of you know how I can set the subtitle lines a litte bit higher in the tvscreen?!?
Thnx!![/img]
try the diko forum, http://www.vmesquita.com/forum/
Encoding with diko
By djgazzabhoy in forum Authoring (DVD)Replies: 2Last Post: 13th Dec 2010, 05:49 -
Problem expanding subtitle time with Subtitle Workshop
By Kaze105 in forum SubtitleReplies: 1Last Post: 11th Nov 2008, 22:16 -
Question about DIKO
By Belfour in forum Authoring (DVD)Replies: 7Last Post: 6th Aug 2008, 01:27 -
Error using diko
By thecrock in forum Video ConversionReplies: 4Last Post: 24th Apr 2008, 17:55 -
DIKO for dvd burning
By wristar in forum Authoring (DVD)Replies: 1Last Post: 29th Oct 2007, 14:41
