  1. hey all im trying to make a kvcd from an avi and im using tmpgenc to do it along with a pal kvcd template and its only converting the video part so how do i get the audio part?
    thx in advance
  2. VH Veteran jimmalenko's Avatar
    Aug 2003
    Down under
    I've got a funny feeling that the KVCD templates are Video Only by default, and that the audio part is yours to handle however you so may wish. It should be as simple as changing the template settings to allow audio.
    I'm sure the guys at http://kvcd.net can help you out more with this issue, if you're prepared to pay the $2.99 entry fee to their forums.
    Be warned though that both KVCDs and KDVDs are not compliant, and won't neccessarily play in your player.
    If in doubt, Google it.
