The first time I bought this kind of media and I have simple question. Which DVD-authoring program can burn on double-layered disks? For simple DVD-medias I use TMPGEnc DVD Autor v1.5. Will it work also with DLs? Or should I take some another program? I don't want to simply to try, because this media is rather expansive and the program shows me only 4.7G of media by default. Should I simply ignore this and force it to burn ax much as it is?
TMPGENC DVD Author accepts Dual Layers.
Like you said, it ony shows 4.7gb of media by default .
Open it, click on option, Environmental setting,
and search for Double Layer 8.5 DVD media.
That's it. :O!.
edit
ahhhh he was faster than me.. [...] -
Most authoring programs should support dual layer. I know DVD-lab does, and I believe the Ulead products do as well.
DVD Authoring with Windows MM 2.6 OR AVS Authoring
By jagman in forum Authoring (DVD)Replies: 3Last Post: 8th Oct 2011, 05:41 -
How To Convert DVD Media Made From VHS Media For Sharing Online
By BlazingSpeed in forum Video Streaming DownloadingReplies: 0Last Post: 11th Dec 2010, 14:20 -
Authoring a mixed-media/resolution Blu-ray?
By jbigfoot in forum Authoring (Blu-ray)Replies: 4Last Post: 20th Jun 2010, 22:37 -
BD25 Media + Bluray Player + Authoring = Inconsistency
By likwid8 in forum Blu-ray RippingReplies: 6Last Post: 15th Apr 2010, 00:15 -
DVD authoring ac3 out of sync after authoring but not before
By Genaugmen in forum Authoring (DVD)Replies: 1Last Post: 29th Jan 2010, 20:16
