Hi,
I tried to convert a VCD with 2 languages into a DVD but only to capture 2 channels into 1.
Please advise. Thanks.
Results 1 to 9 of 9
TMPGenc DVD author does the job beautifully - select bilingual audio. Good luck!
Hi Huiwinsun,
I have tried converting it from the VCD by using ISO Buster on the .dat file. I was unable to separate 2 audios. I don't think TMPGenc DVD Author can do multiple ripping of VCDs into a DVD. -
Originally Posted by Elminster73
Originally Posted by huiwinsun
I'm trying to do it from a mandarin Karaok VCD to a DVD.
Thanks. -
Hi, karaoke vcd should not be a problem. Rip with ISObuster, then use TMPGEnc Dvd Author to process the mpegs and create the menu. The advantage of TMPGEnc Dvd Author is its option for bilingual audio and conversion of the audio to dvd specs. Good luck.
How to convert a bi-language VCD .dat file into a mono-langu
By pengyou in forum Video ConversionReplies: 6Last Post: 22nd Jul 2011, 10:25 -
Convert DVD with choice of audio language and burned-in subtitle language
By theproof in forum DVD RippingReplies: 2Last Post: 24th Jun 2010, 17:34 -
How Panasonic DMR-E80H convert japanese to english Language
By tanveerriaz in forum DVD & Blu-ray RecordersReplies: 0Last Post: 9th Feb 2010, 07:30 -
Guide Needed for Authoring Multi Language DVD with multi language menus
By kemimich in forum Authoring (DVD)Replies: 2Last Post: 24th Dec 2008, 16:46 -
SUPER convert DVD to DPG default language
By slclark in forum Video ConversionReplies: 3Last Post: 23rd Aug 2007, 02:24
