Hi,
I have a bunch of mpegs at 352x288 (PAL) MPEG1 resolution with a bitrate of ~1800. I want to stuff the all on to a DVD (NTSC). Should I convert them to 352x240 MPEG2 or 720x480 MPEG2? What is recommended? Does it really matter? I use ULEAD MF3 for DVD authoring.
Thanks!
They are dvd compliant as-is, author away.
"Art is making something out of nothing and selling it." - Frank Zappa -
Not that simple, they need to be converted from PAL to NTSC 352x240, audio may need to be converted as well.
Buy My Books -
My DVD player (Pioneer) plays back pal. You might want to try and find a player that will play pal as well b/c converting pal to ntsc is a PIA.
Guides here: https://www.videohelp.com/guides.php?howtoselect=4;41#4;41"Art is making something out of nothing and selling it." - Frank Zappa -
Thanks for all the feedback guys. So it sounds like as long as have my audio DVD compliant, 352x240 MPEG2 is a good choice? I have SW that will do MEPG conversion and can handle 352x288 MPEG1 to 352x240 MPEG2 (and make the audio compliant)
If you wanted to leave them PAL, then it's an easy conversion. If you put them into TMPGEnc DVD Author, I believe it will convert the sound to 48K and author the files to PAL DVD spec. If you want to convert them to NTSC, that is a fair bit more complicated, as stated.
Never used it specifically for that, but VSO DivxToDVD might work for the conversion from PAL to DVD NTSC. It would certainly be easier. -
Sorry, didn't mean to imply that all you have to do is change the framesize to convert from PAL to NTSC as it requires a framerate conversion as well, so you'd have to make adjustments to the audio whether it was already at 48K or not.
Buy My Books
Auto adjusting screen resolution to video resolution
By Computer Nerd Kev in forum Software PlayingReplies: 11Last Post: 11th Jul 2011, 06:36 -
What's the best format and resolution for LCD TV or HDTV from DVD and VCD.
By newbievideohelp in forum Video ConversionReplies: 6Last Post: 6th Nov 2009, 13:23 -
High-Resolution VCD/SVCD Stills on the UNIX Command Line
By sterno in forum User guidesReplies: 7Last Post: 20th May 2009, 12:16 -
viewing a QVGA/VGA resolution video with NTSC DV resolution (with a TV)
By Lightbreaker in forum EditingReplies: 1Last Post: 6th Jan 2009, 01:57 -
16:9 resolution for DVD-R?
By Gaelstrom in forum Authoring (DVD)Replies: 6Last Post: 31st Oct 2007, 04:33
