Whenever I cap at 640x480 in virtualdub in Huffyuy frames always drop. Frames don't drop at all when I cap in Virtual VCR with the same settings. Any ideas why?
vdub is a vfw app
virtual vcr is a wdm app
When you cap with vdub with any win nt based os like winxp, you are going through a nt vfw2wdm filter written by ms. This filter/translator is slow and can be buggy which leads to errors. Vdub is a great app but the base code was written for win95 and win98 vfw (vxd) drivers.
I use vdub for many things but not capturing.
Don't take that as a knock on vdub it's just the reality as documented by the author.
btw) This is how it shows up in your system devices:
Microsoft WDM Image Capture (Win32)
and this is the actual filter/wrapper dll name which is usually in the system32 directory:
vfwwdm32.dll -
When i capture with VirtualDub i use this method...
First i get all the resolution and capture codec settings (etc) as i want them.
Then i do a 60 second test capture.
On the VirtualDub capture panel you'll see Avg frame size and it'll report the average frame size for the test capture.
I then use the Disk I/O setting on the Capture menu.
I set the Chunk size so that it's larger than the average frame size and the Chunks in buffer to a value higher than the framerate that i'm capturing at - in fact i generally set Chunks in buffer to 32.
Can't swear that it'll fix your problem but by my way of thinking it'll do no harm!
Martin. -
I changed my chunks and unchecked everything in capture sync and choose do not resync between audio and video streams. Here's a sample of something I capped and encoded in vdub.
http://pranksnfiles.com/crow/SampleCap.avi
Bug in VirtualDub (?) -- can't cut desired number of frames
By ralf07 in forum Video ConversionReplies: 3Last Post: 21st Sep 2011, 18:50 -
Virtualdub VCR capture no dropped frames but 5400 inserted frames in 1 hour
By suloku in forum Capturing and VCRReplies: 12Last Post: 17th Aug 2011, 23:33 -
Avisynth drops blank frames?
By wfael in forum EditingReplies: 3Last Post: 9th Dec 2008, 23:06 -
inserted frames without dropped frames in VirtualDub capturing VHS
By whschlebaum in forum Capturing and VCRReplies: 0Last Post: 23rd Aug 2007, 21:59 -
VirtualDub Dropping Frames when capturing VHS
By big_al_40 in forum Capturing and VCRReplies: 8Last Post: 4th Jun 2007, 16:57
