Ok.. I have a movie that plays fine on my comp, but when i try to burn it to DVD, I get a reallocation files error.. So I tried to use the IFO method of creating new IFO files by deleting all the IFO and BUP files and creating ifo's for VTS_01_0.VOB through VTS_01_4.VOB The problem is the menu file (VTS_01_0.VOB) "played" the menu like it was part of the movie.
If I use the IFO method leaving the menu file out, I lose out on the menu...
Any suggestions are more than welcome
The files are:
VTS_01_0.VOB - menu
VTS_01_1.VOB through VTS_01_4.VOB - movie
It might help if you explained how you are attempting to burn it to CD, as in what means you are authoring it. Have you tried using a freeware program such as DVD Shrink, do Open Files and point to the files you're talking about and then create an ISO image from that? You can then mount the ISO image using tools such as Alcohol 120% as a virtual dvd drive and see if it plays using your player before burning it to DVD using DVD Decrypter, Nero, or whatever burning software you desire.
prob joining VOBs; also sync prob with another movie
By spiritgumm in forum EditingReplies: 5Last Post: 19th Jun 2010, 09:32 -
make menu for existing vobs?
By MilesAhead in forum SVCD2DVD & VOB2MPGReplies: 5Last Post: 3rd Jul 2009, 12:34 -
Make menu for a movie dvd that have subtitle and have not any Menu!
By p_samimi in forum Authoring (DVD)Replies: 1Last Post: 13th Feb 2009, 14:29 -
Need to create video DVD with menu & chapters from VOBs. Any suggestion
By mr_tinka in forum Authoring (DVD)Replies: 2Last Post: 4th Feb 2008, 16:26 -
How create menu to Vobs ??
By Seasonal in forum Newbie / General discussionsReplies: 8Last Post: 23rd Sep 2007, 14:10
