Today I bought the JVC DR-M10S.
And I am really satisfied with the quality of the recordings i made (even up to 3hours on one disc!)
But the downside is that I cant find any option to crop or zoom before capture.
On tvcards its easy to youst add a black border over the trackingline error or whats it called, before encode.
Does any DVDRecorder support this function to add a black border on the bottom of the video in realtime?
I quess I cant youst add a black border in some DVD Authoring application without re-encode the whole thing?
Results 1 to 10 of 10
Why does it matter?
And no, most capture cards cannot crop it either.
Only a select few.
And "cropping" is terrible advice. You might want to mask it at most (cover it with black), but stretching and cropping ruins the image.Want my help? Ask here! (not via PM!)
Ok tnx
I guess im youst always looking for errors when I buy new machines (before the "return back to store week" is over), so I was worried I had done a bad choice.
And I only see this line when i watch the DVDs in my computer, so maby its not a big deal.
I was almoust waiting an answer like: Why didnt u buy the x model 5$ more and u get rid of the line or something.
Ok I see now i formulated that one bad i mean.
That when I capture to avi with my tv-card I have a choice to add border in tmpgenc, youst to hide the border. -
As you noticed, it only shows up on a computer monitor. A TV has 'Overscan' that hides the edges of a capture. From the 'Glossary' to the left. <<<
"Overscan
The area at the edges of a television tube that is covered to hide possible video distortion. Overscan typically covers about 4 or 5 percent of the picture."
If your final destination is TV, you should safely be able to ignore the distortion. -
Please change that to:Originally Posted by redwudz
If your final destination is CRT TV, you should safely be able to ignore the distortion. On TFT screens there is no overscan that I know of. -
Dragonsf, agreed. I was thinking of the more common CRT TV. I'm not that familiar with TFT TVs.
I know, I had to change my knowledge too after buying a WS HDTV TFT . I have to blank/crop those parts (top and bottom) before converting to DVD. There are some drawbacks going to modern equipment, but it's worth.Originally Posted by redwudz
Better equipment has filters that zoom the overscan.
I've noticed the same problem when I use my InFocus digital video projector to view my homemade DVD-Rs that I made on a Panny E-85.
It's a minor bummer.
Yip.
- Jim"An intellectual carrot? The mind boggles!"
Sharp VCR (or similar) S-VHS quality for best capture of my VHS tape?
By ruehl84 in forum Capturing and VCRReplies: 0Last Post: 19th Feb 2012, 16:52 -
Which $150 or under capture card for VHS/S-VHS -> computer?
By HDClown in forum Capturing and VCRReplies: 25Last Post: 16th Apr 2010, 23:16 -
VHS to DV capture: Component video vs. S-VHS
By vega12 in forum Capturing and VCRReplies: 8Last Post: 19th Feb 2009, 20:42 -
Capture analogue with 720x576 has tiny horizontal bar at bottom
By ManUtdFans in forum Capturing and VCRReplies: 15Last Post: 21st Jan 2009, 14:12 -
Remove noise from VHS bottom border
By roglopes in forum Capturing and VCRReplies: 10Last Post: 21st Jun 2007, 15:36
