Last month 2 good wishes on a wish list post were mentioned and just want to know when it may be added to the programme.
1,Abort / cancel button etc for when you are doing an avi conversion and did not hit the autofit button.
2,An check box option to delete left over s2d files as when you choose your asset files it then creates the same name followed by_S2D.mpg in that same folder if so this is a good wish as many time`s my assets files are not allways in the source file folder thus leaving duplicate files all over the place.
Also 1 question did you mention something weeks ago about should you forget to hit the avi autofit button it would automatically do it for you ????.
Results 1 to 10 of 10
I have sent you a build to test with 1 & 2 complete. Please let me know how it goes so that i can then put on the website.
TIASVCD2DVD v2.5, AVI/MPEG/HDTV/AviSynth/h264->DVD, PAL->NTSC conversion.
Actually I'd love to test out a version with these features myselfOriginally Posted by ChrissyBoy
A64 X2 3800+ | Chaintech VNF4 Ultra | EVGA 6800GS | 1GB Corsair PC3200 | Maxtor DM9 120GB SATA | Antec Sonata II | Dell 1905FP UltraSharp -
only 1 of the 2 tasks works.
Chris was going to sort something out and send another build for me to play with saturday but nothing as yet.
Possibly to busy with other issues that are more needed ?. -
Yes, I've been sidetracked with some subtitle shenanigans.... I will try to get a build up tomorrow or the day after.
No i haven't. Basically at the moment: If SVCD2DVD completes it's job then it will delete the intermediate _S2D files (if you have elected it to do so). If you abort the process then it doesn't.
Do you have any news regarding the avi situation that if you abort the proces it will remove the s2d created files and not leave them as previous posts shown above.
Cheers. -
Not yet. I have been doing other things. I will get to it shortly. In the meantime if you abort a processing run you will have to be responsible for cleaning up the files produced.
"attention chrissy boy" Update message shown whilst burning.
By IPBR21054 in forum SVCD2DVD & VOB2MPGReplies: 6Last Post: 3rd Jul 2010, 12:36 -
A waterfall for a little boy
By bryankendall in forum Off topicReplies: 2Last Post: 26th Jun 2010, 19:03 -
Netframework problem Chrissy
By sc0tsman in forum SVCD2DVD & VOB2MPGReplies: 5Last Post: 19th Sep 2007, 18:08
