Hey,
I have a divx file, but the audio is not loud enough.. you can barely hear the talking even with the volume of my speakers at max.. is there any way to get the audio of the file louder?
thanks
Steven
or turn up your volume on your speakers
I just said in my post:Originally Posted by BJ_M
"you can barely hear the talking even with the volume of my speakers at max.."
So, what are you trying to say? -
what about the volume from windows ..
other than that - you will have to do what Baldrick suggests (or in combination) or demux the mp3 file , fix it (does not require a re-encode though ussually = unless WAY low (which requires proccessing)) and remux it .."Each problem that I solved became a rule which served afterwards to solve other problems." - Rene Descartes (1596-1650)
Loud buzz when outputting audio only
By joelkranz in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 4Last Post: 15th Mar 2014, 23:12 -
Poor Audio: Effects Loud, Dialog too Soft
By stormdragon in forum Newbie / General discussionsReplies: 4Last Post: 25th Sep 2011, 20:02 -
Captured audio is REALLY LOUD
By justin81 in forum Capturing and VCRReplies: 4Last Post: 11th Aug 2009, 08:43 -
GUI for dvdauthor - audio too loud
By mrcoolekin in forum Authoring (DVD)Replies: 6Last Post: 15th Oct 2008, 05:25 -
16bit Audio on XL1 not Loud enough!
By ozab in forum AudioReplies: 16Last Post: 13th Aug 2007, 10:33
