Overburning this type of CD with Mac seems not possible, can anyone help ?
My movie capacity is more than 700 MB
Results 1 to 12 of 12
please post mac questions in our mac forum section. moving you.
MissingMediaBurner
All you need"Good Luck 007"
In Memory of Desmond Llewelyn -
Roast does overburns, too. But it requires X11 (comes with Panther, Tiger, can be downloaded from Apple).
MMB is propably easier to use.i-NCO -
I always used Firestarter FX for overburning.
-laugh while you can monkey boy! - Dr. Lizardo -
The current Firestarter FX's beta periord expired earlier this month. And an update hasn't been posted.
That beta expiration thing is so obtuse and annoying. I wish the developer would quit with that...
There is a new beta of Firestarter FX
http://www.projectomega.org/subcat.php?lg=en&php=products_firestarter#dl -
My question was if I have an avi movie which exceeds 700 MB to fit in the normal CD-R disk, I can use Firestarter FX to make smaller, do I understand well or I have to use a 800 MB CD ?
I tried to copy on 800 MB CD-R but not possible I don't know if is the type of CD or what
Thanks -
Has anyone been able to get Firestarter to work with a Pioneer DVR-108 and OS 10.3.9? If yes, what driver are you using in Firestarter's Preferences. Any other tips on getting Firestarter to work with my set up would be appreciated.
Problem w burn for Mac
By allakantralla in forum Newbie / General discussionsReplies: 1Last Post: 25th Dec 2011, 20:12 -
Unable to burn a DVD (Mac)
By kayar in forum Authoring (DVD)Replies: 4Last Post: 9th Jan 2010, 14:36 -
How to Burn an ISO on the Mac
By Jeff_NJ in forum MacReplies: 6Last Post: 19th Nov 2008, 10:11 -
Capture PC burn for mac
By TripScott in forum Video ConversionReplies: 2Last Post: 5th Nov 2007, 15:34 -
How to burn a ISO file on a Mac? Can this be done?
By babybreese in forum MacReplies: 9Last Post: 30th Aug 2007, 21:45
