Hey there i want to encode some footage i have captured from my camera from DV to DivX with vegas. I have vegas 6 and DivX create installed how do i encode to DivX?
Results 1 to 14 of 14
Select Render from the file menu. Choose AVI as your output format, then custom to set codec and codec configuration. That said, from what I can see you don't use Vegas if you have Divx Create - it does the conversion for you.
Read my blog here.
Ok i see. Buts whats the difference between " DivX(R) 6.0 codec" and "DivX(R) 6.0 yv12 codec"
Ok i Encoded it with DivX (6.0) then tryed playing it with divX player. I get all this interlacing how can i fix that. SHould i use better encoded or what?
That would be because your DV source is interlaced.
Either de-interlace before encoding or de-interlace on playback. -
vegas 6 has very good deinterlacing -- it is covered in your manual .. just choice the type in project properties ..
also check off reduce interlace flicker"Each problem that I solved became a rule which served afterwards to solve other problems." - Rene Descartes (1596-1650) -
What de-itnerlace the best? & where do i turn off reduce interlace flicker?
don't be offended but maybe you should not have purchased such a high end NLE , as this is very basic stuff in vegas and covered in the manuals . $600 out the window ...
it is in project properties and antiflicker is in media properties .."Each problem that I solved became a rule which served afterwards to solve other problems." - Rene Descartes (1596-1650) -
WHen encoding the video what de-interlace should i use.
-blend fields
-interpolate fields -
blend slow motion
interpolate fast motion
there is a veg file over at the VASST site to do deintelacing pre vegas 6 , where it uses the same media in two tracks .... supposed to work very well"Each problem that I solved became a rule which served afterwards to solve other problems." - Rene Descartes (1596-1650)
Having trouble importing avi's (divx/xvid) and mkv's into Vegas 10
By mr-scarface in forum Video ConversionReplies: 11Last Post: 17th Jan 2012, 10:11 -
Need a little help with Sony Vegas and Divx
By 1Wolf in forum EditingReplies: 1Last Post: 16th Jul 2011, 09:08 -
Importing xvid and divx into vegas - a solution ?
By BJ_M in forum Video ConversionReplies: 55Last Post: 13th Apr 2010, 15:16 -
Problems encoding from Vegas to Divx and AC3
By grendizer in forum Video ConversionReplies: 0Last Post: 6th May 2008, 04:30 -
vegas, divX and AC3 issues...
By bettytron in forum EditingReplies: 11Last Post: 30th May 2007, 05:04
