    May 2003
    Oz
    Here's the script:
    LoadPlugin("C:\Program Files\AutoGK\DGMPGDec\DGDecode.dll")
    # LoadPlugin("C:\Program Files\AutoGK\AviSynth\plugins\Decomb521.dll")
    DirectShowsource("C:\Documents and Settings\Temp\Encoding\filename.wmv")
    LanczosResize (448,525)
    # ConvertToYV12()
    Telecide(order=1,guide=1)
    Decimate(cycle=5)
    # ConvertToRGB24()
    AssumeFPS(25)
    Now when I load that into TMPGEnc Plus 2.5 TMPGEnc just closes. No warning dialogs, no error messages, nothing, it just closes. If I remark out the LanczosResize line, it works perfectly. Same thing happens for a Lanczos4Resize as well.
    Anyone got any idea why the LanczosResize function isn't working?
  2. Member adam's Avatar
    Sep 2000
    Try removing the # in front of ConvertToRGB24()
    Jan 2003
    India
    Originally Posted by DRP
    Here's the script:
    # ConvertToYV12()
    Decimate(cycle=5)
    # ConvertToRGB24()
    AssumeFPS(25)
    You cannot resize to odd number of pixels. Change the lanczosresize to
    lanczosresize(448,528). As mentioned by adam, you might also need to adjust the color space.
    Why don't you load the file directly in TMPGEnc? It will work very well!!
    May 2003
    Oz
    Thanks for that. Got it fixed
