Hello,
I'm using MainConcept MPEG Encoder (MME) and convertings AVI's to DVD elementary audio and video streams. When it's done I load them into DVD-Lab Pro and I get a warning that says:
"Open GOP's were detected in the file. The file will play fine but Chapter points may not start accurately. In your encoder always choose closed GOP's"
When I click on "Details..." then "Advanced..." in MME it has the following settings in the "GOP Structure" section.
I Frames: 15
P Frames: 3
Auto GOP: Fast
Closed GOP Interval: 1
Do I have this setup wrong or is there another setting I should look for? Please help!
I have MME and DVD-lab PRO (DLP) also and I received this message the other night. I set the Closed GOP interval at 1 as you have set, but I had the Auto GOP set to None, and the DLP message didn't show that time. Apparently, when Auto GOP is set to Fast or VCSD, it leaves the GOPs open. I guess by definition they have to be open when you are doing scene detection, because it has to place the I-frame at the scene change and that may interrupt a GOP that was already being formed.
I don't think that open GOPs will be a problem. DLP merely brings it to your attention. The fact is you will be able to be able to place chapter points exactly where you want them: at the scene changes that were detected by MME.Tools used: ScenalyzerLive 4.0, Adobe Premiere Pro 2.0, Adobe After Effects 7.0 Professional, Adobe Encore DVD 2.0, IFOedit 0.96, DVD-lab PRO 1.53, Adobe Audition 2.0
which is better Mainconcept MPEG Encoder or H.254 Encoder
By d_unbeliever in forum Newbie / General discussionsReplies: 7Last Post: 4th Aug 2012, 18:14 -
Some Mainconcept MPEG Encoder questions.
By scott274 in forum Video ConversionReplies: 9Last Post: 15th Jul 2008, 03:08 -
MainConcept MPEG Encoder 1.5 question
By hanugro in forum Video ConversionReplies: 6Last Post: 21st Feb 2008, 20:27 -
Closed GOP
By kitty in forum GlossaryReplies: 1Last Post: 12th Feb 2008, 23:14 -
Avi to DVD (mpeg2) in Mainconcept Mpeg Encoder, basic how to
By reboot in forum User guidesReplies: 31Last Post: 6th Aug 2007, 15:56
