Hi,
I just got this new OEM Nec 3540A after my Pioneer 106 gave up the ghost.
Everything seemed ok. I am only burning dvd-r discs (burned with Toast 5.2.3 rippeed with MTR) and am playing them on a newer Panasonic Player and my older JVC player (about 6 years old.)
I have had no problems in writing discs that played ok on the older drive until now!! Discs burned (dvd-r) play ok on the Panasonic, but won't play properly on the JVC. The JVC is an older player and i know that it has problems playing dvd+r discs. But, these are dvd-r discs that won't play on this player. My old Pioneer never had any problems.
I am using the drive in a firewire enclosure. Toast sees the drive properly and accesses it.
From what I've read, i can't change the book type for -r on the Nec 3540A. Has anyone seen this problem? It seems like a book type problem as all my later players seem to have no problem.
The firmware is 1.01. I am also using Toast 5.2.3 on the Mac to burn the disc.
Any help is greatly appreciated!!!!
Russ
Results 1 to 1 of 1
Video files I add more for a burned disc won't read on my DVD recorder
By Indrek in forum DVD & Blu-ray RecordersReplies: 5Last Post: 8th Jan 2010, 08:30 -
really screwy issue: PC will not read cdr-audio disc after it is burned
By mazinz in forum AudioReplies: 12Last Post: 1st Jul 2009, 00:38 -
Dvd Burner only reads older dvds, won't read newer ones all the sudden??
By kpaxfaq in forum DVD & Blu-ray WritersReplies: 6Last Post: 28th Feb 2008, 15:11 -
My player won't play burned discs anymore.
By uNderdog_101 in forum DVD & Blu-ray RecordersReplies: 14Last Post: 30th Dec 2007, 17:44 -
DVD recorder LG DR175B won't read burned DVD but common DVD Player reads it
By Mycow in forum Newbie / General discussionsReplies: 0Last Post: 12th Aug 2007, 18:59
