Hi
I'm capturing DV through ADVC on to Premiere Pro 1.5.
Near the end of the miniDV tape for about 4 seconds the frames are corrupted with lots of blocky 'rainbow' coloured squares.
I would work around the distortion, BUT these particular frames are very important (just a brief moment of someone who is no longer here).
When the blocks appear - they come with a lot of scratchy 'noise'.
Is there anything out there that could fix this problem.
I am new to this, but I was thinking if it was a .jpg I'd fix it
"pixel by pixel" with Photoshop.
Is it possible to fix each frame in this way, on video?
If so, any pointers on how?
Many thanks in advance.
Stephen
Hi DP,
You can export the section from Premier as a "Filmstrip" (title.flm).
You can then import into PS and treat it as a .jpeg. You then export as a filmstrip back into Premier.
When you export you only get the image not the audio, so you'll need another piece of software for that.
Bill -
First the ADVC is just a switch for a DV source so should be irrelevant.Originally Posted by Dear Prudence
In the last 4 seconds on a 1 hr tape, the DV camcoder is in shutdown and you can't expect smooth data. This will be tough.
I hope LabanB's approach works for you.Recommends: Kiva.org - Loans that change lives.
http://www.kiva.org/about
Corrupted MiniDV tape
By glitchee in forum MediaReplies: 1Last Post: 29th Feb 2012, 15:19 -
Corrupted MP4 in QT
By Klagar in forum Video ConversionReplies: 4Last Post: 27th May 2011, 08:28 -
corrupted mp3
By knutrockney77 in forum AudioReplies: 1Last Post: 22nd Apr 2011, 04:21 -
How can VHS tape color loss be possible? ("tape fade")
By lordsmurf in forum RestorationReplies: 31Last Post: 18th Oct 2010, 10:32 -
Corrupted DVD-R
By dvd impaired in forum Newbie / General discussionsReplies: 1Last Post: 25th Sep 2009, 17:33
Hi
