just wondering if anyone knows how i can hook computer speakers up to my home stereo? so sound comes out the sub and all 5 speakers??
anyone???
nowhere near enough information provided to answer.
"To steal ideas from one person is plagiarism; to steal from many is research." - Steven Wright
"Megalomaniacal, and harder than the rest!" -
Most computer speakers have their own amplifier. You may be able to hook them to a receiver through the 'Line Out' or 'Monitor' RCA jacks.
You would need a stereo RCA male plug to a stereo 1/8" phone female jack adapter. You can probably get one at a stereo store or similar. DO NOT try to use the speaker outputs of the receiver.
If you are trying to get 5.1 sound from your reciever, this won't do it, at least with just stereo sources. -
need to know the specifications of the speakers
need to know the specifications of the receiver (what types of signal is it capable of generating and more importantly, what kind of outputs does it have)
most likely, yes, it will be quite easy to connect the speakers to the receiver -- just plug 'em in!
but as redwudz said, this may or may not give you 5.1 sound.
PC speaker systems are a bitch, and just about every brand has their own fucked up idea of how they should operate and be connected.
whereas normal home theatre systems are all configured pretty much the same way. none of this green plug, pink plug, orange plug bullshit -- the front right speaker connects to the front right output, the subwoofer connects to the terminal labled "SUBWOOFER".
shit, just connecting my PC's sound card up to my receiver's 5.1 inputs was a pain in the ass (back to that whole multi-colored plug bullshit), especially since the damned outputs on the card were labled incorrectly."To steal ideas from one person is plagiarism; to steal from many is research." - Steven Wright
Connect Home Theater Speakers to PC.
By therock003 in forum AudioReplies: 10Last Post: 24th Sep 2010, 21:25 -
Using computer speakers for my tv.
By imdaman in forum AudioReplies: 12Last Post: 28th Nov 2009, 11:47 -
Can I use the 5.1 speakers from my home cinema system without the dvd play
By leeuk321 in forum DVD & Blu-ray PlayersReplies: 3Last Post: 2nd Aug 2009, 18:29 -
LG home theater, speakers giving problem.
By sajjadbaqir in forum Media Center PC / MediaCentersReplies: 7Last Post: 5th Sep 2008, 19:01 -
Play my MP3's from Computer to My Reciever
By mn072065 in forum Media Center PC / MediaCentersReplies: 9Last Post: 8th Nov 2007, 21:47
