  1. Whats the best way to make menus for SVCD???I was wondering whats the best way so I decided to ask you guyz for help..Because I want to make an SVCD With menus....I no how to make and SVCD with the chapters but not MENNNUS..So please help me..
    Please Help
    Thanx,
    Joey
  2. i think the best way is ULEAD DVD Movie Factory makes Menu's for VCD, SVCD, and DVD great progie
    Jun 2001
    If you think ulead movie factory is the best, you are not a real SVCD fan. UMF has a lot of problems that need to be corrected and improved. Its chapter is not real, ff does not work sometimes, goto does not work well, and etc.. The only good thing is it is very easy to use.
    I recomend videopack5 (I am not working for roxio) for authoring, ulead video studio for DV edit, TMPGenc for encoding.
    <font size=-1>[ This Message was edited by: tendtend on 2001-12-19 20:07:05 ]</font>
  4. If dollar for dollar TSCV is the best (ie. it's free). You can d/load the newest ver at http://www.ttool.org and there's a good guide for the program at:
    http://www.personal.psu.edu/users/r/d/rdm186/
  5. VCDimager is very good, and not very hard to understand xml code. You can try TSCV (VCDImager's GUI) and after you've done a couple of menus I think you will be able to author your own XML.
    Nov 2001
    Texas
    NERO has a menu option built in that is VERY easy to use.
    Nov 2001
    Raleigh, NC
    @mkaylor - have you gotten Nero SVCD menus to work? I never have. VCD works fine, but not SVCD. What version of Nero are you using and what kind of standalone do you have?
