Hi
I'm having a problem using Canopus ADVC 100 with Premiere Pro 1.5 when using my JVC DV camera.
PPro has no problem connecting my camera direct through the Firewire, it captures with no problems.
I think I've got the wiring set up right - but it freezes PPro.
Wiring Setup;
JVC camera DV/OUT (4 pin) into rear of ADVC 100 (6 pin).
4 pin from front of ADVC straight into 6 pin PC Firewire card.
Shouldn't that work?
I have been capturing VHS through ADVC with no problems.
I have changed the settings on PPro for DV input.
Any idea?
Thanks a lot.
Stephen.
Plug the camcorder into a different IEEE-1394 port on the computer. When using the camcorder "device control" in menus should be on. When using the ADVC for capture, "device control" should be off.Originally Posted by Dear PrudenceRecommends: Kiva.org - Loans that change lives.
http://www.kiva.org/about
Loading 5.1 wav in PPro or Soundbooth, side channels missing? (Audition OK)
By Asterra in forum AudioReplies: 0Last Post: 20th Apr 2012, 01:11 -
How to Rip a DVD for re-editing in PPro CS5
By trikcard in forum Video ConversionReplies: 2Last Post: 31st Aug 2011, 16:16 -
Replacing footage in PPRO CS4
By sterankin in forum EditingReplies: 18Last Post: 23rd Aug 2010, 07:03 -
GEEKS! I just bought the Canopus ADVC-300 and I need your input and advice!
By _yo_wasup_ in forum Capturing and VCRReplies: 22Last Post: 3rd Jul 2009, 17:49 -
Jagged edges upon PSD inserting in PPro
By Vially in forum EditingReplies: 0Last Post: 12th Sep 2008, 17:34
Hi
