Over the last year or so I have been burning a fair amount of DVD's, and from both your comments major and my own observations, I have concluded that using the ffmpeg codec to encode mpeg2 files yields a higher quality end result (albeit marginal in some cases).
The problem is, most time when I encode files using the ffmpeg mpeg-2 settings, the video bitrate skyrockets (let's say, on average, for 2-3 frames, not sequential) to some value way over the average bitrate (as high as 9-10,000 kb/s).
To try to counteract this problem I have messed around with the qmin/qmax settings (Usually aim for 2-15, but have had to go up as high as 2-30).
Although rare, there were at least one or two cases where I had the qmin/qmax setting set at 2-30 and still got a bitrate spike.
Basically, I'm wondering if there is something I can do to avoid these problems in the future. Is it simply a matter of having to set qmin/qmax to 2-32 each time just to be safe, or is it something else?
Some info in case you need it:
Avg bitrate: Usually between 3900 and 4200 kb/s
Framerate: 29.97 (Even when source matertial is NTSC FILM, as I switched over to using mpeg2enc codec for DVD burning, so I have not fiddled around with using ffmpeg then performing a pulldown of the encoded files)
Filters: None
Options: High Quality, 4 Motion Vectors, 2-Pass Encoding, Trellis Quantization, Quarter Pixel Motion Estimation, Decode with Quicktime
Keyframe Interval: 12-15
Qmin/Qmax: Same as previously mentioned
I hope that's all you guys need. Thanks a lot.
help - how to compile latest "nightly" ffmpeg for win32 (XP) with mingw
By hydra3333 in forum ProgrammingReplies: 32Last Post: 20th May 2017, 00:33 -
TMPGEnc "clip total bitrate too high for a DVD-Video" issue
By dread in forum Authoring (DVD)Replies: 7Last Post: 26th Oct 2010, 15:34 -
TMPGEnc says "clip total bitrate is too high for a DVD-Video" but it's not?
By sasuweh in forum Authoring (DVD)Replies: 24Last Post: 30th Sep 2010, 03:17 -
how we can implement "VirtualDub" or "FFmpeg" with my C# windows applicati
By dhemittal in forum ProgrammingReplies: 0Last Post: 8th Jun 2010, 07:17 -
DVD Flick error message "ffmpeg.exe has stopped working"
By stewiegriffin711 in forum Authoring (DVD)Replies: 4Last Post: 17th Aug 2008, 07:20
