Hi!
I want to create a dvd out of a 3 CDs DivX movie with seperate subtitle files.
I know how to join avi's using several different programms. The problem, that now occurs is, that these parts overlapp around 10seconds (last 10secs of first part are again in the beginning of part 2). what would be the easiest way to correctly join these files without getting the subs out of sync, so that I can encode the whole movie to dvd with selectable subs?
A different question I have is: What is the output resolution I should set in for example TMPGEnc Xpress if the input AVI is said to be 704x567? should I set normal resolution 720x567 oder set 704x567 or even 352x288 as tmpgenc suggests? (I know that this is a noob-question).
thnx in advance for you help!
cheers,
hereander
