i just got my nec 3540a.
i'm using TTG02 dvd-r 8x and ProdiscF01 dvd-r 8x media.
when i use dvd decryptor to burn an ISO file, the write speed starts at 4.1x, then 2 minutes later, goes to 6.0x, then 2 minutes later, goes to 8.3x, 2 minutes later goes to 7.3x, then 1 minute later goes to 8.3x, then 1 minute later the burning process is complete.
takes about 9 and a half minutes for a full dvd-r disc.
is this normal?
i remember using my cousins pioneer dvr-108 with the same media, the write process started at 8x and stayed at 8x till burning was complete (about 8 minutes)
by the way, the "device buffer" on dvd decrypter doesnt always stay at 100%.
it goes down to 85% to 98% every 8 seconds. one time it went down to 20%.
pc specs:
p4 2.8ghz hyper thread
200gb hdd
512mb ddr
geforce 6600 128mb -
I am right there with you having the same trouble with my NEC. My Pioneer 109 has issues with the buffer also, so I thought I would try one of these drives. Ultimately, I stuck with my 108-best burner I have ever had.
P4 3.2 800 mhz FSB
1.5GB PC3200
Plenty of hard drive--Drew -
My Pioneer A06 and LG 4081 act in the same way. Buffer goes down to 0 and up to 100% all the time. I've tested everything. It happen when phisical free memory goes down for an unknown reason.
Music Cd Burning Software - Record 3 cd's at the same time
By mn072065 in forum AudioReplies: 10Last Post: 5th Jun 2009, 10:02 -
First Time Burning DVD (vob)
By Wanderlustus in forum Authoring (DVD)Replies: 17Last Post: 9th Jan 2009, 15:16 -
Burning as Divx- burn time-why so long-alternates?
By Rik62 in forum Newbie / General discussionsReplies: 2Last Post: 12th Jul 2008, 18:19 -
Long time burning and skipping problems
By championjosh in forum DVD & Blu-ray WritersReplies: 8Last Post: 16th Feb 2008, 02:11 -
Burning time taking 2 hours???
By Its Pink Ninja in forum Newbie / General discussionsReplies: 8Last Post: 3rd Jun 2007, 17:55
