Can someone recommend the best and most effective method for converting MPEG-1 (1150kbs) files to Xvid (1.1 beta 2), using virtualdub?
My goal is to reduce the size while mantaining as much quality as possible.
I've spent the last few days tinkering with virtualdub with very dissatisfactory results
MPEG-1 file info
1150KBS video bitrate
224 CBR audio
aspect ratio: 352x240
Using Virtualdub
Compressed with Xvid 1.1 Beta 2
Filter:
Aspect ratio: 320x240
Precise Bilinear
Compression:
2-Pass
AS-5
Quantization type: MPEG-Custom (eqm_v3lr.xcm custom matrix)
Adaptive Quantization: NO
Interlaced: NO
QPEL: NO
Global Motion: NO
BVOPS:
Max: 2
Quantizer Ratio: 1.50
Quantizer offest: 1.00
Packet Bitstream: NO
Motion Search: 6-Ultra High
VHQ: 1 - Mode decision
Use VHQ for Bframe: NO
Use Chroma motion: YES
Turbo: Yes
All Quantizer are set to 2-31
Audio: Lame MP3 128Kbits
Target size: 300MB
My original mpeg-1 file is 480MB (47 mins), after converting it was reduced to 210MB. As you can see the final output file size is alot smaller than what I specified. I was not sastified with the video quality at all.
There are alot of noise around the edges and the color isn't as bright as the original source.
I tried switching the custom matrix to "eqm_v3ehr.xcm (High Bitrate)", same spefication as above. This time the final output size was 330MB. The quality difference was minimal compared to the (210MB) file, not worth the 120MB difference.
I also tried using the default Quantization type: H.263, again i wasn't happy with the result.
What settings/filters would you recommend for converting MPEG-1 file to XVID? Are there any filter that would help me reduce the blockiness/noise (very minimal) of mpg1 files?
I would like to maintain as much quality as possible while reducing the file size by 40-50%.
I would use AutoGK, which is a front end for virtualdubmod and AVISynth. Perhaps try extracting a 1 minute section to use for testing using TMPGEnc's MPEG Tools > Merge and Cut, then setting the "Target Quality" percentage to 80, and seeing if that gives you satisfactory results on your test encode. If not, repeat the test with a % of 90, and so on .....
If in doubt, Google it. -
Thanks for the suggestion. Will third party filter for Virtualdub work with AutoGK? That's one main reason why i'd rather work with Virtualdub, because there's alot i want to add to the video after i encode it.
Settings Xvid codec in Virtualdub
By Docoptik in forum SubtitleReplies: 7Last Post: 6th Mar 2011, 15:15 -
VirtualDub/Xvid question: YV12 vs. XVID FourCC in the xvidvfw.dll driver???
By KneeRow in forum Video ConversionReplies: 14Last Post: 1st Aug 2010, 14:35 -
Virtualdub settings to capture DV
By magillagorilla in forum Capturing and VCRReplies: 12Last Post: 11th May 2010, 14:42 -
Recommend a GOP setting for PAL-DVD/MPEG 2 files?
By Dark Alpha in forum EditingReplies: 1Last Post: 25th Jan 2008, 22:41 -
Can anyone recommend at good program for converting DVD to Divx or Xvid?
By gbgunner in forum DVD RippingReplies: 13Last Post: 10th Nov 2007, 18:18
