Which is better and why?
Also, have given up on trying to correct an audio video sync issue with one movie - Dr. DivX gives me the best result over all others, btw. Anyway, why would one particular movie have such a problem?
Results 1 to 9 of 9
Better for what?
The "XviD Vs DivX" argument has been done to death here.
My personal opinion is that XviD is better, and that's based on a number of experiments I've completed to form my own opinion on the matter.
It might be an idea to check out the Doom9 Codec shootout.If in doubt, Google it. -
Personally I tend to prefer DivX.Originally Posted by loopyloops
I find for the encodes I do, that Xvid seems to produce a sharper, more colour vibrant picture. But at the final size / quality I tend to convert, I'm much more likely to see macroblocks with Xvid.
On the other hand, DivX doesn't seem to give me quite as sharp a picture - nor have quite the vibrancy that Xvid does. However, I don't find macroblocks in the encodes I do, so it wins out for me. -
I think it's close enough that it doesn't matter. I use Xvid because it's open source. I usually use Quantization mode at Q=2. I don't care how big the resulting file is.
I think it's for each individual to decide which is best for them.
Personally, I am sticking with DivX because it is much less problematic for my players.
audio sync issues occur for many reasonsOriginally Posted by loopyloops
encode using the wrong setting
poor capture method
problem with the original file such as a glitch
eg glitch in an mpeg2 capture off a tv card can lead to an audio sync issue in an avi created with autogk
would need more details on what you are doing when av sync occurs
eg converting a dvd to xvid using autogk
or capturing off vhs via svideo in and line in audio
generally audio sync is difficult to fix
if it is a constant amount out then can determine how much this is in a player such as media player classic then fix it
if the sync gets progressively worse or is out by varying amounts in the original file then it is almost impossible and very time consuming to attempt to fix it
My DivX DVD Player can't play my avi DivX/xvid video
By Baldrick in forum DVD & Blu-ray PlayersReplies: 32Last Post: 6th Mar 2015, 09:11 -
Would synch mostly occur on DVD to DivX, or XviD to DivX?
By rocky12 in forum Newbie / General discussionsReplies: 3Last Post: 29th Oct 2008, 01:01 -
Does divx author reencode Divx and xvid files?
By Onceler2 in forum DVD RippingReplies: 4Last Post: 26th Aug 2008, 18:16 -
Weird I don't have XviD or DivX codec installed but I can see Xvid movies
By Talayero in forum Software PlayingReplies: 4Last Post: 5th Jun 2008, 11:47 -
Make an unplayable Xvid/Divx video play in a divx standalone Player
By AllenGorden in forum Newbie / General discussionsReplies: 4Last Post: 31st Dec 2007, 17:25
