Sorry if this is a stupid question.
I've just encoded a PAL AVI file using stand-alone CCE 2.7, which I've not used before. CCE outputs a bunch of files with the following extensions:
*.ecl
*.mpv
*.vaf
*.wav
To author I'm using DVD Architect but this refuses to accept any files other than *.wav. What am I doing wrong? What authoring prog should I be using? How do I get em 'in there'?
Many thanks!
nzo wrote:
.ecl is CCE's project settings.*.ecl
*.mpv
*.vaf
*.wav
.vaf is CCE's pass generator.
.wav is audio
.mpv is a generic video file
Rename the .mpv to .m2v within the preferences dialogue box, or the filename itself..
Any authouring program should recognize .m2v..
Good luck... -
I've never used CCE or DVD Architect, but the first thing that I would try is to ignore the vaf and ecl file. Then try changing the mpv file extension to m2v. I use DVD-lab PRO and Adobe Encore DVD and they both like the m2v and wav extensions.
Tools used: ScenalyzerLive 4.0, Adobe Premiere Pro 2.0, Adobe After Effects 7.0 Professional, Adobe Encore DVD 2.0, IFOedit 0.96, DVD-lab PRO 1.53, Adobe Audition 2.0
Cinema Craft Encoder Sp 2.67.00.27
By Gwar in forum Video ConversionReplies: 1Last Post: 19th Feb 2012, 12:32 -
Problem with Cinema Craft Encoder SP and Windows 7
By echo1434 in forum Video ConversionReplies: 6Last Post: 24th Dec 2011, 17:51 -
NEW VERSION: Cinema Craft Encoder SP2 1.00.01.01
By devilcoelhodog in forum Latest Video NewsReplies: 10Last Post: 18th May 2008, 12:46 -
Help with Cinema Craft Encoder
By Topcat360 in forum Video ConversionReplies: 31Last Post: 29th Jan 2008, 17:51 -
Cinema Craft Encoder Plugin
By MI6 in forum Video ConversionReplies: 1Last Post: 11th Aug 2007, 19:05
