    Feb 2004
    I am a free man.
    Sorry if this is best suited elsewhere.
    If this forum is wrong i know it'll get moved so.....
    I have been using DVD Shrink for some time, and know that it stores a little info about every DVD that it analysis.
    I appreciate that the amount of info being stored about any one DVD is going to be minimal, but i am sure that the sheer number i have done is gonna start clogging something up, and not just drive space.
    My question is where is this info stored, and how do i get rid of it?
    thx in advance
  2. I forget exactly where it is, but it's easy to flush it with CrapCleaner.
    Pull! Bang! Darn!
  3. Aging Slowly Bodyslide's Avatar
    Feb 2002
    A Different Timeline
    Stored in this folder:
    C:\Documents and Settings\[username]\Application Data\DVD Shrink 3.0\
    Just select all the files in the folder press delete or move to the trash and Goodbye.
  4. ...It can also be in All Users\Application Data\DVDShrink,make sure to enable 'Show hidden files and folders'.
    In Win98/Me it's in Windows\Application Data\DVDShrink.
  5. Mod Neophyte redwudz's Avatar
    USA
    My Shrink folder was in 'All Users' and I had to enable 'Show hidden folders and files' in Folder Options to make the Application Data folder visible.
    EDIT: MOVIEGEEK was faster.
    Feb 2004
    I am a free man.
    Thank you
