I capture programs via Windows Media Center. I'm capturing them in 5.1 surround. From there I use TMPGenc Xpress 3.0 to convert to MP2 and then TMPGenc DVD Author 1.6 to get the DVD files. Is there a better way to do this that will keep the 5.1 when I go to DVD? The way I'm doing it right now is only giving me 2 channel stereo.
Any help would be appreciated. I searched the board but can't seem to get a direct answer.
Results 1 to 14 of 14
Demux the audio from your source, encode video to .m2v, then author with the 5.1 and .m2v to DVD.
Quality is my policy. -
Virtualdub-MPEG2 should work for you. Go to streams list and demux the audio there.
Demux your audio from your source file(s). Convert Video Only with TMPGEnc to produce a M2V file. Then when using TDA, use your M2V and the 5.1 AC3 file you demuxed and it will retain the 5.1 ch.Originally Posted by m82492
If your source is AVI then virtualdubmod would be my tool of choice. If your source is MPEG then I'd use TMPGEnc's MPEG Tools. There's more demuxing programs here.If in doubt, Google it. -
Thank you for the suggestion. I completely understand what you are telling me to do now. I'll give it a shot!
Matt -
One last question and I'll go away....my source file is a dvr-ms file from Windows Media Center. I'm I usually convert these files to mpeg2 via TMPGenc Express. After the remultiplex it seems like it's still in 5.1 but I can't be sure. I didn't think Express supported that. Anyway...is there a way to remux a dvr-ms file to take the audio directly from those files?
Let's just clarify something here - all multiplexing does is join the video and audio fields together. This is of course different to encoding from two different source files. So long as you're not encoding, and all you're doing is multiplexing, TMPGEnc won't be converting the file, so if your source audio is AC3 and you multiplex it with a video stream, then it will stay AC3, regardless of if you have the AC3 plugin or not. It only uses the AC3 plugin for decoding or encoding, not simply copying a stream byte for byte. To be sure, download the latest GSpot Beta (2.52) and load the remuxed MPEG into it. It will tell you what type of audio is in the file.
I tried the Gspot program on some of the remultiplexed files and it came up as n/a for the audio. I'm not real sure what exactly TMPGenc does to the DVR-MS file. It pulls the Windows Recorded TV files into it and says it's remultiplexing before it can encode. After the remultiplexing I get some sort of an MPEG file. After I get that file I must have TMPGenc encode it which takes about 2.5 hours for a full length football game.
It's a compressed file, like a zip file. You need to un-rar it, try this: http://www.download.com/ExtractNow/3000-2250_4-10228183.html?tag=lst-0-10Originally Posted by m82492"Art is making something out of nothing and selling it." - Frank Zappa
Well I think I made a big discovery through all of this. I was under the impression that TMPGenc Express requires you to
1. Remultiplex the DVR-MS into an MPEG-2 which takes only 10 minutes for a full length football game
and then
2. Encode at an appropriate NTSC setting which takes about 2.5 hours for a full game.
Your questions made me think about this a bit more than I did in the past. There is no need for me to encode the MPEG-2. I can load it into TMPGenc DVD Author, edit, render the DVD files and then burn. It worked great. Quality was awesome. I guess I just need to mess around with demuxing that MPEG file before rendering the DVD File in DVD Author.
Thanks for your help. Sorry for my ignorance. I am truley learning this hobby on the fly!
I appreciate your help!
stereo downmix: surround vs surround 2
By codemaster in forum AudioReplies: 7Last Post: 29th Aug 2012, 12:06 -
DVD to AVI with surround sound
By Sutekh in forum Blu-ray RippingReplies: 1Last Post: 12th Aug 2009, 13:47 -
By Sutekh in forum Newbie / General discussionsReplies: 1Last Post: 12th Aug 2009, 13:46 -
how to burn 5.1 surround dvd
By namesake in forum DVD RippingReplies: 5Last Post: 5th Oct 2008, 00:34 -
5.1 Surround Sound on DVD
By Adhishyajnik in forum Authoring (DVD)Replies: 1Last Post: 15th Jun 2007, 02:57
