I was wondering about this, because I juts purchased a Panasonic PV-GS12, and don't have a firewire card or wire. I used the USB port to transfer my videos with Windows Movie Maker. To say the least, I wasn't impressed. According to that quote, a firewire transfer will be much faster and of better quality than the USB I am using now? I don't know whether to buy a firewire port or not, I just want to be sure that there will be a big different in the clarity, and not just the speed. Will it be that noticeable?Most MiniDV or Digital8 camcorders only provide a highly compressed video stream on the USB port intended for internet streaming. The USB port is also used for still transfer.
To get a full quality DV transfer, you need to use the IEEE-1394 (aka Firewire, ILink) ports.
Yes to get the full quality of the DV video use firewire. Just remember that it is raw video not compressed.To get a full quality DV transfer, you need to use the IEEE-1394 (aka Firewire, ILink) ports.When it sounds too good to be true, it usually is!!
dv is not raw, I believe it's compressed 5:1
Just because you aren't paranoid, doesn't mean they aren't out to get you!
URGENT! Firewire card for computer
By dakota413 in forum Capturing and VCRReplies: 9Last Post: 10th Aug 2011, 18:22 -
does capture of firewire use the sound card?
By Cazz in forum Capturing and VCRReplies: 4Last Post: 24th Jan 2010, 17:45 -
Motherboard Firewire versus Add-in Card Firewire
By SCDVD in forum Newbie / General discussionsReplies: 7Last Post: 19th Jun 2008, 12:19 -
DV Camera to DVD plus Firewire Card Help.
By Sikander in forum Capturing and VCRReplies: 6Last Post: 12th Oct 2007, 15:35 -
What Firewire Card for a Camcorder?
By rakun in forum ComputerReplies: 5Last Post: 12th May 2007, 10:20
