I am interested in playing around with DVD-VR mode DVD-RW discs produced by my Pioneer recorder. While these discs didn't mount at all under Mac OS X 10.3, I noticed that under 10.4 Tiger they now mount.
On the other hand, although the discs mount, so far I haven't been able to read anything off of them. I can drag and copy over the .IFO file, but every time I try to copy over the .VRO file I get an error -50. Even trying from the command line fails.
Does anyone have any idea what is going on and how I can access files on these discs?
Well, ReadDVD is pretty bad so I don't even consider it a product
and the fact that it requires a kext file means I just won't use it.
Toast 7 doesn't install any drivers. When Toast 7 is launched and the media browser is selected, Toast will then read and load the discs. If the disc is a standard DVD, it will read the IFO files and load all the titles and chapters. You can still use it in the Finder though.
Toast doesn't mount DVD-VR in the Finder, it just allows access to the files on the disc and allows you to see all the video files. In 10.4, the finder mounts DVD-VR, but since they can't be accessed correctly, Toast will unmount the disc and use access the drive. You can extract Disc, Title and Chapter.
Another cool things is if you mouse over a title in the media browser, Toast will display the video info. MPEG type, Aspect Ratio, Size, Audio, etc.
If you have multiple images or discs mounted, Toast will see all of them in the browser also.
I've tried about 30 DVD-VR disc including DVD-R, DVD-RW, DVD+R, DVD+RW, and DVD-RAM from set-top and camcorders and they all work great in Toast so far.
I highly recommend Toast 7 for VR.
Any tools for copying / reading bad quality discs?
By Locut0s in forum DVD RippingReplies: 2Last Post: 12th Nov 2010, 08:06 -
(sloved) Windows 7 problem reading dvdrw in vro mode
By Wizard23 in forum ComputerReplies: 5Last Post: 19th Nov 2009, 20:21 -
DVDFab HD not reading discs.....
By E_Merlin in forum DVD RippingReplies: 19Last Post: 19th Jan 2008, 21:40 -
problem reading some discs
By nick6878 in forum DVD RippingReplies: 5Last Post: 3rd Jan 2008, 10:25 -
Panasonic ES30V Stopped Reading blank discs
By newshoes in forum DVD & Blu-ray RecordersReplies: 5Last Post: 25th Oct 2007, 15:50
