I need a sms service that works in most countries for a project that I'm working on. So I would like to know if the pswin sms service works with your mobile operator, try for free:
http://www.pswin.com/_pswincom/static/testeng.html
don't forget to include the country code and remove initial 1 or 0 like
447755588333 (UK)
12125551212 (US)
Post back if it worked or not and what country you are in.
Results 1 to 14 of 14
Please test this service also
http://www.clickatell.com/brochure/index.php (top right, Test our Gateway) -
They both work in Australia Baldrick. And pretty quick too.
micGod created man and finding him not sufficiently alone, gave him a companion to make him feel his solitude more keenly. -- P. Valery -
No -> http://www.pswin.com/_pswincom/static/testeng.html
Yes -> http://www.clickatell.com/brochure/index.php
To Calgary, Alberta, Canada -
Both ok on UK Vodafone
thanks! Clickatell supports many more US and Canada mobile operators and they seem to work fine in europe also.
both work in the netherlands on T-mobile
Just because you aren't paranoid, doesn't mean they aren't out to get you! -
My project is done, www.mymemorizer.com , a free web calendar with email and sms reminder service.
I (and my brother) just needed a very simple web calendar and couldn't find something that I liked...so I made one. I didn't think of making it available for the entire world but I had a server over so why not. -
i killed it on the year 5000 -- or the earth will be destroyed by then i guess ...
http://www.mymemorizer.com/?y=5000"Each problem that I solved became a rule which served afterwards to solve other problems." - Rene Descartes (1596-1650) -
VERY nice...."Who was that masked man?"....Originally Posted by Baldrick
the earth will be destoryed year 2038, http://www.mymemorizer.com/?y=2038
Tried - 65 country code.
Working -http://www.pswin.com/_pswincom/static/testeng.html
Working - http://www.clickatell.com/brochure/index.php
Freaking fast too....
Is there a small test video one can use to test Rec 601 / 709 conversion?
By Asterra in forum Video ConversionReplies: 5Last Post: 19th Jun 2011, 08:28 -
Streaming in flash player & SMS CHAT
By Yogurtinsh in forum Video Streaming DownloadingReplies: 0Last Post: 7th Dec 2010, 14:56 -
[b][url]TEST! TEST TEST! WHAT"S THE BEST?!!!!!!!111111
By lordsmurf in forum TestReplies: 0Last Post: 2nd Aug 2010, 02:30 -
Need to make test tool to test Dolby
By djai in forum AudioReplies: 0Last Post: 9th Jun 2010, 06:01
