    Aug 2005
    s america
    is there a noticeable difference in quality passing from one format or the other? i'm just uncertain as to wait to get a good card to capture uncompressed video or stick with what i have and do some dvd's from dv videos.
    5
  2. Member edDV's Avatar
    Mar 2004
    Northern California, USA
    5
    Unless you are doing some unusual filtering, you will get best results staying with the original DV created in the camera, then transferred over IEEE-1394. No capture is necessary. It is already digital video and audio.
    DV matches DVD format closely. Levels match for YUV, PCM 16 bit 48Khz sound is a match. Edit in DV. Encode to MPeg2 and you are done.
    DV & DVD levels: YUV, 8bit/component, black=16, white=235
    DV & DVD size: 720x480 (4:3 or 16:9)
    DV & DVD sound: 16bit, 48KHz
    http://www.kiva.org/about
    USA
    What edDV said. Uncompressed AVI is about 112Gb/hour. DV is about 13Gb/hour. One good reason to use DV.
    If you use a capture card and capture to AVI in a compressed format such as Huffy or a more compact AVI format such as PIC Video, you may have better quality than DV. It depends on your source video. If it's DV, you will gain nothing.
    Capping from a VHS tape is not usually a high quality source and DV would be fine. HDTV would be a example of a high quality source and a capture card should give better results than DV, depending on the capture format, but with a lot more work and HD space needed. If you want to learn about capture cards and their quality, http://digitalfaq.com/ is a good place to start.
  4. Member edDV's Avatar
    Mar 2004
    I was assuming source was a DV camcorder or analog to DV capture device.
  5. Member Capt.Video's Avatar
    Nov 2005
    Like they were saying, your best bet is DV to MPEG2, and skip the capture cards all together.
    I have TRV120 by Sony and use the "pass through" feature when backing up VHS tapes. Ive tried just about everything, and only this gives the BEST quality results with full D1, no drop frames and perfect A/V sync.
    Good luck,
    Andrew
    I have been into computers since 1980. Ive been tinkering with DV in one flavor or another since 1990.
